LabWindows/CVI
ComToFile function
Hi Experts,
Does anyone have experience to use ComToFile function? It looks the function to write COM data to any file, but there is less information only in help, espaecially "File Handle". I would refer any example or more detail information. I apreciate for your help.
Tetsuya
(5,275 Views)
The file handle is simply an integer handle that refers to a pathname.  Get this handle by calling OpenFile.  In that function, you can set your pathname.
The rest of the Com library is pretty straightforward.  Take a look at its sister function ComRdTerm.  There's a sample project listed in the help: ~\rs232\serial.cws
(5,268 Views)
Thank you very much.
The function is related with FileI/O function. I will check them.
thanks,
(5,248 Views)
