LabWindows/CVI
sscanf and NaN floating point
I do not understand what is wrong.
If I convert a double variable with value NaN with sprintf, it correctly converts to string "NaN".
When I run the reverse, string to double by sscanf it fails and the number is not converted.
I do not understand where wrong. printf and scanf should handle NaN. Where is the error?
Help me understand.
Test code:
char DoubleStr[50];
double Valdouble;
i=0;
DoubleStr[0]=0;
Valdouble=NotANumber();                                           //After This Valdouble==NaN, DoubleStr=="",i==0 (OK)
i=sprintf(DoubleStr,"%lf", Valdouble);                         //After This Valdouble==NaN, DoubleStr=="NaN", i==3 (OK)
Valdouble=0.0;        //After This Valdouble==0.0, DoubleStr=="NaN", i==3 (OK)
i=sscanf(DoubleStr,"%lf",&Valdouble);                      //After This Valdouble==0.0, DoubleStr=="NaN", i==0 (Why "NaN" not be conveted and stored in Valdouble?)
Thank You.
(5,711 Views)
Nothing is wrong, it's a missing feature, see here and here
(5,696 Views)
I thank you very much for the quick response.
After this I tried a solution "manually", and it seems to work well.
Test code:
char DoubleStr[50];
double Valdouble;
i=0;
DoubleStr[0]=0;
Valdouble=NotANumber();                           ​                //After This Valdouble==NaN, DoubleStr=="",i==0 (OK)
Valdouble=0.0;                                    ​                            //After This Valdouble==0.0, DoubleStr=="NaN", i==3 (OK)
i=sscanf(DoubleStr,"%lf",&Valdouble);             ​         //After This Valdouble==0.0, DoubleStr=="NaN", i==0 (Why "NaN" not be conveted and stored in Valdouble?)
i=0;
if(stricmp(DoubleStr,"NaN")==0)
{ Valdouble=NotANumber(); i=1; }
else if(stricmp(DoubleStr,"+Inf")==0)
{ Valdouble=PositiveInfinity(); i=1; }
else if(stricmp(DoubleStr,"-Inf")==0)
{ Valdouble=NegativeInfinity(); i=1; }
else
{ i=sscanf(DoubleStr,"%lf",&Valdouble); }
But there is some other way more elegant and faster to accomplish this?
There anything in winapi to solve this?
I should make parsing of large quantities of data and already the standard "sscan" is quite slow.
Thank you very much.
(5,675 Views)
