Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Comment generer signal d'horloge d'une frequence 50hz ou inferieur
eliaL
Member
03-16-2005
02:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
je cherche a réaliser un créneau 0-5V d'une fréquence 50hz ou inférieur. je dispose d'une carte PCI6025E et de CVI5.5
merci d'avance
0
Kudos
Message
1
of 2
(2,940 Views)
Reply
Re: Comment generer signal d'horloge d'une frequence 50hz ou inferieur
RobertoBozzolo
Proven Zealot
03-16-2005
04:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I suggest you take a look at STCGenerateSquareWave example (located in
\samples\daq\ctr
with appropriate values in
and
parameters you can obtained the desired frequency and duty cycle for the generated wave.
0
Kudos
Message
2
of 2
(2,936 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
