LabWindows/CVI
Compile Options
I want to compile my code to a .obj, not an NI niobj or NI debug nidobj.  The help contents suggest Options>>Create Object File
but I don't see this selection in the options pulldown.  How do I do this ?
RTyson
(3,441 Views)
did you search the 'options' in the source editor window (see screenshot) ?
(maybe you are referring to the 'options' menu in the project/workspace pane ?)
Once the game is over, the king and the pawn go back into the same box.
(3,437 Views)
I found out that your cursor must be located within the source file you want to compile then the Options menu has this selection available in the pulldown.  I was selecting the file on my project tree and then accessing the Options pulldown menu which did not have the selection available in this mode.
RTyson
(3,427 Views)
