Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
avoiding to load the same program two times
busing
Member
11-11-2005
03:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to have only one copy of my LabWindows-program in memory. It should not be possible to load a second instance. How to do so? Thanks Busing
0
Kudos
Message
1
of 3
(3,303 Views)
Reply
Re: avoiding to load the same program two times
RobertoBozzolo
Proven Zealot
11-11-2005
04:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
A solution to this problem can be found in a sample distributed with cvi: look at oneinst.prj project that you can find in <cvidir>\samples\utility directory.
1
Kudo
Message
2
of 3
(3,303 Views)
Reply
busing
Member
Author
11-11-2005
05:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Good luck. Busing
0
Kudos
Message
3
of 3
(3,296 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
