05-18-2010 11:27 AM - edited 05-18-2010 11:28 AM
ColeTrain wrote:Hey KavehV.
I did some asking around here and did not come up with anything solid. Could you offer a few more details on what these custom attributes are that you're refferring to? Are you thinking just free fields that aren't neccessairly tied to any specific message/frame? More along the lines of a traditional database type file?
I'll do you one better. Here are the lines in the DBC that I'd like access to through the API:
BA_DEF_ "NetworkName" STRING ;
BA_DEF_ "BusType" STRING ;
BA_DEF_DEF_ "NetworkName" "";
BA_DEF_DEF_ "BusType" "CAN";
BA_ "BusType" "CAN";
BA_ "NetworkName" "PT";
They're defined in any DBC editor as "custom attributes" (we're using Vector's CANdb++ to generate these). For your XNET api, it should be a simple matter of coming across anything that's a custom attribute and treating it as a key/value pair. Give APIs for a listing of custom attributes, if a "key" exists, and retreiving the value for that "key". It should be simple to do with the hash table libraries already available in toolbox.h (disregarding RT compatibility, which is a problem with toolbox.h). I would do it, but I don't have access to modify XNET source code, so it's something NI is going to have to provide.
10-05-2011 05:16 AM
Kaveh,
I realize this thread has gotten old now, but I was recently experimenting with DBC files, attributes, and value tables, and I came across your thread. I'm not sure how long it has been available, but there is a VI in the LabVIEW XNET API called "XNET Database Get DBC Attribute.vi". This VI has a couple of different modes, but one of them seems to allow you to read the attributes and values from a DBC file for a cluster, frame, signal, or ECU. In your example, it seems to successfully find the BusType and NetworkName and their values when I search within the "cluster" object.
Obviously, this functionality may or may not be available in CVI.
Some other notes:
-the Help states that only one "Mode" is available, but I have had success using all of the modes.
-I had some trouble with value tables associated with multiplexor/multiplexed signals, but R&D seems to have fixed the bug (NI Support Reference # 7330655)
Karsten
