 ricklin888
			ricklin888
			04-26-2012 10:58 AM
I am trying to configure PXI-4022 current amplifier in labwindows/CVI, but I can't find any function call in the NI-DMM help.
The help file only mentions how to set current gain with labview vi.
Is it possible to control 4022 in labwindows, or must use labview only to let it work?
Thanks.
 Wolfgang
			Wolfgang
			04-26-2012 11:07 AM
Hope it gets you started: http://zone.ni.com/reference/en-XX/help/370384N-01/dmm/cvi_tutorial/
04-26-2012 11:32 AM
Hi,Wolfgang,
Thanks for your quick reply. I found most of the measuring function in NI-DMM are for digital multimeters such as PXI-4050,4060,4070...,
but the function for current amplifier (such as PXI-4022) is not listed in NI-DMM (or I missed it). I am tring to config current range in PXI-4022
with Labwindows/CVI. There are 3 setting I can change (1mA,10uA,100nA) if I use Labview vi, I don't know whether I can finish the same function
with Labwindows/CVI?Could you kindly tell me how to do that or the name of function call using in Labwindows/CVI? I am appreciated of your kind help.
