LabWindows/CVI
Configure PXI-4022 in Labwindows/CVI
I am trying to configure PXI-4022 current amplifier in labwindows/CVI, but I can't find any function call in the NI-DMM help.
The help file only mentions how to set current gain with labview vi.
Is it possible to control 4022 in labwindows, or must use labview only to let it work?
Thanks.
(3,300 Views)
(3,296 Views)
Hi,Wolfgang,
Thanks for your quick reply. I found most of the measuring function in NI-DMM are for digital multimeters such as PXI-4050,4060,4070...,
but the function for current amplifier (such as PXI-4022) is not listed in NI-DMM (or I missed it). I am tring to config current range in PXI-4022
with Labwindows/CVI. There are 3 setting I can change (1mA,10uA,100nA) if I use Labview vi, I don't know whether I can finish the same function
with Labwindows/CVI?Could you kindly tell me how to do that or the name of function call using in Labwindows/CVI? I am appreciated of your kind help.
(3,292 Views)
