LabWindows/CVI
Configuring counters in a 6602 in tandem with counters on a 6071E
Could someone help me with a snippet of code to redirect the gate on two
counters on a PCI 6602 through RTSI so that the gate input is read from PFI0
on a PCI 6071E?
Also, How do I select the 20 mhz clock on the 6602 to be in sync with the
clock on the 6071E?
Many thanks
LVilla
(3,049 Views)
LVilla
You will need to use the Select_Signal function and the GPCTR_Change_Parameter function.
First, set the PFI0 line on the 6071E to goto a RTSI line using the Select_Signal fucntion. (Signal Name = RTSIx, Signal Source = I/O Pin 0)
Second, set the Gate of the 6602 to read from the RTSI line. Use the GPCTR_Change_Parameter function for this. (Parameter Type = Gate, Parameter Value = ND_RTSI_x, where x is the RTSI line.)
I hope this info helps you get started on this application.
(3,049 Views)
LVilla
Brian L
(3,049 Views)
