LabWindows/CVI
Convert ViChar to double.
I am trying to convert a ViChar to a double and have tried using the following exmaple...
static ViChar daqmeasure[256];
double measurement;
measurement = (double) daqmeasure;
I am getting the following error...
Cast from pointer to ViChar to double is illegal.
Can someone explain a possible solution?\
ThanksNAdvance
(4,535 Views)
Assuming the ViChar daqmeasure[256] variable contains a floating point double value in binary form (and is not an ascii string) you can convert it by
measurement = *(double*)daqmeasure;
daqmeasure is a pointer, so CVI would not let you cast it to a double directly.
If you want to step through the array use
measurement[i] = *(double*)&daqmeasure[i*sizeof(double)]; in a loop.
If the data in ViChar is really a string value (easy to see by looking at the array in the debugger) you can use atof() to convert the string to a double value or if it is an array of doubles stored in a string use the CVI function Scan().
(4,521 Views)
It is a string but your instructions were not clear...
Thanks!
(4,520 Views)
Maybe:
    measurement = atof (daqmeasure);
will meet your needs?
JR
(4,506 Views)
JR_2005
I'm new to LabWindows and had never seen or heard of the atof command.
I apologize for my stupor.
Thanks alot!
FredTest
(4,492 Views)
Hi Fred,
The ViChar data type is just like a regular char datatype; however, VISA has placed a wrapper around it to increase portability. So, simple ViChar casting would work in the following situation:
ViChar mychar;
double mydouble;
mydouble = (double) mychar;
However, your case is different beacuse ViChar is an array. In your case you can use one of two methods to convert the data to a double.
1) If the data is a string in the character array, for instance:
daqmeasure[0] = '7';
daqmeasure[1] = '.';
daqmeasure[2] = '3';
daqmeasure[3] = '2';
Then you should use the atof function:
2) If the data is in a binary string you can follow Function to Convert Binary in String Format to a Float or Double.
With some minor tweaks, this could help you convert a binary string to a double.
Matt Mueller
NI
(4,489 Views)
