LabWindows/CVI
plot sine signal
        I want to generate a sine signal,now I use sinewave() function ,when the frequence is larger than 1,  I can get full period sine wave,But when frequence is smaller than 1 ,I can't get full period sine wave ,how can I do ?Thank you!
(3,718 Views)
Hi ????,
First off, perhaps the issue you are seeing is related to the KnowledgeBase
Why Do the SinePattern and SineWave Functions Not Generate A Full Waveform Cycle?
Secondly, we have a bunch of analysis CVI examples that use the SineWave() function such as peaktest, polyfit1, spectrum, thd, and windowing. Locate these examples by launching the Example Finder (Help >> Example Finder), choosing the Search tab, and typing in "analysis".
Hope this helps!
Best Regards,
Jonathan N.
(3,690 Views)
