LabWindows/CVI
Convert .doc to .rtf file
I am trying to open a .doc file in LabWindows/CVI, then save this file as an .rtf file without using macros.  I need to do this since I need to open the file as an ASCII file using LabWindows/CVI and search for various key phrases in the file.
I am using Windows 10 operating system and LabWindows/CVI Version 8.0.1.
I have Word 9.0 Object Library (word2000.fp) and WordReport (wordreport.fp) instruments loaded
Here is my coding (this section works fine):
RESULT = WordRpt_ApplicationNew (VTRUE, &WORD_APP_HANDLE); // Opens new Microsoft Word application
RESULT = WordRpt_DocumentOpen (WORD_APP_HANDLE, TEST_FILE, &WORD_FILE_HANDLE); // Opens file in variable "TEST_FILE" which is a .docx file using the Microsoft Word application
when I execute the next line, the line saves the file as C:\TEMP\New_Test_File.rtf, but the file is still in .doc format (when opened with Notepad, it is still a binary file).  I need it to be an ASCII file, which can be searched easily.
RESULT = WordRpt_DocumentSaveAs (WORD_FILE_HANDLE, "C:\\TEMP\\New_Test_File.rtf"); // Save word file as .rtf file
(1,723 Views)
If you just need to find text within the file, how about if you try saving it as HTML instead? You can use the function WordRpt_DocumentSaveAsHTML.
(1,685 Views)
There is one problem with converting to an .rtf file.  If the text has formatting or is part of a text table, you have to write a routine to strip off the formatting code as shown below:
.txt file
Pressure (mb)
990.1
.rtf file
{\rtlch\fcs1 \af1 \ltrch\fcs0 \fs20\cf1\loch\af1\hich\af1\dbch\af1\insrsid16721103 \hich\af1\dbch\af1\loch\f1 Pressure (mb)}{\rtlch\fcs1 \af1 \ltrch\fcs0
\fs20\cf1\loch\af1\hich\af1\dbch\af1\insrsid10499488 \nestcell{\nonesttables
\par }}{\rtlch\fcs1 \af1 \ltrch\fcs0 \fs20\cf1\loch\af1\hich\af1\dbch\af1\insrsid16721103 \hich\af1\dbch\af1\loch\f1 990.1}
(1,662 Views)
