LabWindows/CVI
Table cell with Numeric Slide type
I know that in a table every cell can have a different type choosen from:
  • numeric
  • string
  • picture
  • ring
  • combo box
  • button
I wonder if there is some hack to set the cell type to Numeric Horizontal Level Slide.
It would be really useful for me.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,710 Views)
No, there isn't any practical way that I can think of.
On the other hand, if your slide doesn't have to be interactive, and if you could replace your table with a multi-column tree (which can look fairly similar to a table, other than for numeric cells) then you could use a horizontal bar cell, which trees do allow, and which is a reasonable approximation of a horizontal slide (You set its value by setting a percentage, from 0 to 100). I'm attaching a screenshot of a table with various cell types in the third column. The blue bar is the horizontal bar cell.
Luis
(4,702 Views)
Unfortunately I need interactive bars, with color ramps and so on...
I think I'm going to write a new product suggestion
Vix
Using LV from 7
(4,685 Views)
I would like to place a progress bar inside a cell, so non-interactive.  In this case, looks like the closest I can come is to make the cell a Picture type and replace the picture with static images.
(2,790 Views)
