LabWindows/CVI
Convert string to LStrHandle
Hi
How can I convert (type casting) Array of Characters or String to LStrHandle in LabWindows/CVI.
Murali
(3,501 Views)
Hello Murali.
Are you trying to convert a character array to a LStrHandle in order to communicate with LabVIEW, to create a CIN, etc?  It might be better if you could provide us with the end result, so we can direct you on the best way to get there.  Check out the following post.  It might give you some additional ideas.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,481 Views)
