LabWindows/CVI
excell: CVI stuck in WriteData
A strange problem encountered:
My Excel2000 demo works fine, but when I wrote my own WriteData() function (very similar to the original), and use it,
CVI gets "stuck" in  the following section:
Error:
    SetWaitCursor (0);
    // Free array of VARIANT
    if (vArray)
        for (i=0;i<ROWS;i++)
            for (j=0;j<COLUMNS;j++)
                CA_VariantClear (&vArray[i*COLUMNS+j]);
        free(vArray);
    // Free SAFEARRAY in VARIANT
    CA_VariantClear(&MyVariant);
Execution is HALTED, and the last line is marked (as if it had a breakpoint), and when I keep pressing F5, this situation reoccurs.
This also happens in Release Mode, which is very strange
Any help would be appreciated
Thanx!
---JM
(3,764 Views)
Some additional info:
1) The last line in the excel table doesn't contain the data it should, but instead   #N/A appears in every cell
2) In Debug Output I get a message reagering a problem with invalid address on the Heap:
HEAP[myapp_dbg.exe]: Invalid Address specified to RtlSizeHeap( 00140000, 0016E838 )
Again any help would be appreciated.
Thanx!
---JM
(3,727 Views)
Make sure MyVariant is initialized. If you call CA_VariantClear with an uninitialized variant then this may cause a First-chance exception and result in your program getting suspended when attached to a debugger. You should always make sure the variant is initialized to some value or set to empty (using CA_VariantSetEmpty).
(3,712 Views)
Jojo,
In your code CA_VariantClear (&vArray[i*COLUMNS+j]), you might want to change it to CA_VariantClear (&vArray[(i*COLUMNS)+j]).  I have noticed that CVI doesn't follow the good old "Please Excuse My Dear Aunt Sally" rules.  For instance if I do a:
int * foo = malloc ( 10 + 1*(sizeof(int)) i will be allocated 14 bytes of memory
Where if I do a
int *foo = malloc ( (10+1)*sizeof(int))) I will be allocated 44 bytes of memory
(3,705 Views)
