LabWindows/CVI
Converting Canvas to Easy Tabs
I have a multithreaded program that runs correctly when I use canvases on my user interface. When I convert the canvases to Easy Tabs and run, none of my user interface components update throughout the run.
The User Interface runs in a seperate thread.
How could using easy tabs effect the updating of my user interface?
I am puzzled.
rink
(3,185 Views)
Rink,
Do you have a small app that replicates the issue on your machine? I was unbale to find anything in our documentation that mentions issues with the easytab feature within a multithreaded application, so we will have to look into it.
Daniel McChane
Application Engineer
(3,185 Views)
Did you do anything else in your program when you added the EasyTabs? Do you maybe have a loop in your program that needs a call to ProcessSystemEvents? Do any UI updates occur before they stop? Do you run any callback functions before the updates stop?
(3,185 Views)
