LabWindows/CVI
How to create a single pulse output signal to one of DIO pins on 6052E card ?
Trying to create and output a trigger pulse within a 6052E card. I only have DIO pins available for output. GPCTR0 and GPCTR1 are already used for other things.
(3,049 Views)
Hello;
The digital lines of that DAQ device of yours don't support strobed operations, meaning that you need a Software call to update the lines.
If your application can work with such constraint, you can use the immediate digital examples of both Labview and NI-DAQ as start point for your development.
Hope this helps.
Filipe A.
(3,049 Views)
