LabWindows/CVI
Converting .fp to .vb file
Hi
I just start to learn Labwindows/CVI 2012.
I would like to convert the .fp file to .vb (which is visual basic .NET)
I was studying sample files of.vb file and I just saw the comment "This code was generated by Measurement Studio for....."
I am asumming that Measument Studio has function to convert the .fp file to .vb file.
Does anybody know how to convert it ?
thanks
(4,331 Views)
I just fingured it out
thanks
(4,323 Views)
Do you mind telling us how you got it to work?
(984 Views)
Sounds like you're not likely to get any response since the OP has connected last time in 2014...
(978 Views)
Dang.
I am maintaining code developed by someone else and there are several cs drivers with "This code was generated by Measurement Studio." noted in them, but I can't figure out how they were generated.  I need to generate some new drivers, and I'd like to keep the same look/feel for APIs.
(972 Views)
