LabWindows/CVI
BUG During set ATTR_TEXT_CHARACTER_SET in Float Ring
I found a serious bug when modifying the ATTR_TEXT_CHARACTER_SET attribute both in code and on UIR.
Modifying the ATTR_TEXT_CHARACTER_SET attribute in a float ring sets all the values ​​of the entries to 0.
This only happens with Float rings.
I use Labwindows\CVI 2020.
Is there a way to fix this? How can I report this bug?
Ciao
Mattia
(514 Views)
It seems this is not happening on CVI 2017 with runtime 2017, at least while editing .UIR files.
Which version of 2020 are you running? I see a few patches have been released both for the IDE and the runtime: maybe updating your software may fix the problem (although no bugs are listed searching the known issues list by "ring" keyword).
(494 Views)
Ciao Roberto,
This is the version of CVI I use. I think I've installed the latest version. NI Package Manager says my system is up to date.
Does this error appear to you?
A short video is also attached.
P.S. Also in LabWindows\CVI 2019 the error not happening
Mattia
(484 Views)
I'm not using CVI2020
(453 Views)
I reported the bug to tech support and a BUG report was created (#3200082).
but he says that "it's unlikely that this particular BUG will be addressed in any future updates, if there are any."
(417 Views)
(389 Views)
