Corruption of CVI button captions?
I am using a LabWindows/CVI 6.0 (Measurement Studion 6.0) installation
that worked fine until yesterday. Now, whenever CVI displays a popup
dialog (MessagePopup, ConfirmPopup, etc...) the button captions are
all screwed up. The button on MessagePopup displays "Load" instead of
"Ok". ConfirmPopup displays "&Add" and "&Ok" instead of "Yes" and
"No".
I have tried completely unistalling and reinstalling CVI (Measurement
Studio) but the problem remains.
Since TestStand 2.01 was also on the machine I have completely
uninstalled/resinstalled TestStand, but the problem remains.
Any ideas what could be causing this? Any ideas of a fix?
TIA
Bob
(2,841 Views)
Hi Bob,
What happens if you create a new application with a MessagePopup? Does the same behavior occur on this new project? I'd like to determine if the issue is with the library or if it's just your specific project and its references. Also, what has changed between the time it worked and now? Something must have happened to either corrupt your project or a library. Let me know what you find and we can continue to investigate. Thanks!
Jeremy L.
Jeremy L.
(2,825 Views)
