LabWindows/CVI
Could not load required CVI.NET modules
I have CVI 2009 and tried to create a .NET Controller in order to access a .NET function.
However I get the error:
"Could not load required CVI.NET modules. Install .NET Framework version 1.1 SP1 or higher and repair the CVI and CVI Runtime Engine Installers..."
However I have .NET 1.1, 2.0, 3,0, 3.5 installed.
Any ideas?
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(4,725 Views)
Hi Ronnie,
Two ideas come to my mind...:
You might have installed NET after CVI, see here: http://digital.ni.com/public.nsf/allkb/71593D05E9A2B787862570D1006D012A
or you might try to generate 64 bit code; for 64 bit, the NET libraries are not yet supported.
Wolfgang
(4,711 Views)
Accepted by topic author Believer
Ronnie,
It was a pleasure speaking with you on the phone today. To help prevent future headaches with others I will share the solution we found.
As mentioned in the KB linked above, we repaired the installation of BOTH the CVI development environment and CVI Run-Time Engine. Just repairing one did not prove to be a solution.
Cheers!
Peter Flores
(4,687 Views)
Thanks Peter!
(4,684 Views)
