LabWindows/CVI
DAQmxWriteCtrFreqScalar() returns DAQmxErrorCannotUpdatePulseGenProperty (-200301) every once a while
I'm curious: does DAQmxWriteCtrFreqScalar() not use/ignore the timeout DAQmx_Val_WaitInfinitely, then?
I'd assume that DAQmx_Val_WaitInfinitely makes the function actually try and retry until it can update the counter and not just try once (?) and thus occasionally fail. Especially with low frequencies around 1-10 Hz.
Message Edited by CVI-User on 04-13-2010 11:15 AM
/* Nothing past this point should fail if the code is working as intended */
(3,281 Views)
do you gat an error message or how do you know that it fails?
Kind regards
Carsten
(3,240 Views)
