Counting TTL pulses from A between TTL pulses from B
I have two sources of TTL pulses. I need to count, from a c/c++ script, how many TTL pulses are received from source A between each of the  TTL pulses received from source B.
I have a PCI-6229 connected to a BNC 2090A, and both of my TTL pulses sources are connected via BNC plugs.
Is there any function that can do that?
I tried to get an example script using the DAQ assistant from LabWindows, selecting acquire signals -> counter input -> Edge count. The function that I got as a result was DAQmxCreateCICountEdgesChan, and I am afraid that it only takes the counter as an argument and not the second digital input that marks the intervals.
(3,061 Views)
From your description it seems to me that the best option is to use two-edge separation measurement. I am not on a PC with CVI installed so I cannot point you to a specific example but this tutorial gives you a brief explanation and some guidance on examples to look at.
(3,057 Views)
