Create Static Library
when i rebuilt the project,i found two lib files be created.
e:\workfile\git\mylibProj\mylib.lib" successfully created.
e:\workfile\git\mylibProj\msvc\mylib.lib" successfully created.
how is the msvc\mylib.lib file come ?
(3,768 Views)
(3,700 Views)
thanks!
Follow your link "https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6EPSA0&l=zh-CN"
in my cvi( labwindows cvi 2013), "File"->"New"->"Project" ,i cannot find "Visual C++" .
(3,549 Views)
Accepted by winter1970
By reading that knowledge base article, I suppose those File > New > Project options are to be found inside the Visual C++ environment, not inside CVI: these are wizards to import some CVI code inside a Visual C++ program.
But this is probably not what you want to use: your project successfully builds a static library to be used inside CVI itself and a separate copy to be called from MS development environments.
(3,535 Views)
