LabWindows/CVI
Create a dll by CVI and call it in VC2005?
I would like to create a dll by CVI8.5 and this dll should by called from VC2005.
I managed to create this dll from \CVI85\samples\dll\simple dll example. In this example, both dll and caller are write by CVI8.5.
Now I would like to change the caller from CVI8.5 to VC2005. I copy the .h .lib and .dll files from dll project to VC2005 project.
I add cvirt.lib and cvisupp.lib. But it still occur link error LNK2019. plz see the attachment.
(2,953 Views)
Have you tried using the following syntax in the header file for the dll that is created by CVI:
#ifdef __cplusplus
extern "C" {
#endif
// prototypes of functions exported by CVI, imported by VC++
#ifdef __cplusplus
#endif"
< td>
This is because VC++ expects function names to be decorated by default, whereas CVI does not. The above syntax tells VC++ to look for plain function names in the dll.
JR
(2,931 Views)
