LabWindows/CVI
how to copya file to a FTP server
hello
could you tell me how copy a file to a FTP server please
I use ds_open to connectmyFTP (with adress ftp://login:password@ftp.domain.com)
and I use copyfile to copy a file fromlocal to ftp server but itdoesn'tseem to work
please tellme how do it
thanx
Message 1 of 8
(4,986 Views)
It sounds like you are trying to mix methods. You can write a file to an FTP server with DataSocket, OR you can use FTP commands (included with CVI's internet toolkit). If you want to use DataSocket, you would:
1) Use DS_Open to open a connection to the FTP file like ftp://login:password@ftp.domain.com/filename.txt
2) Open the local file in CVI with fopen.
3) Read the contents of the local file into a string buffer with fread.
4) Write the string buffer to the DataSocket with DS_Write
5) Close the datasocket connection with DiscardObjHandle
Best Regards,
Chris Matthews
Message 2 of 8
(4,986 Views)
Hi, I have FTP server running on PC1 and i want to read file from that PC1 from PC2(FTP Client) with userID and password. How i have to go. I have LWCVI 6.0.
--Vishnu
Message Edited by Vishnu Patel on 07-01-2008 11:47 PM
Message 3 of 8
(4,566 Views)
Hi Vishnu,
These two knowledgeable articles might be of some assistance.
Essentially, you will use DataSockets to connect to the FTP server, and embed the username/password in the URL.
Writing Data to an FTP Server in CVI Using Datasocket
How Can I Retrieve Data from FTP Servers That Require a Username and Password for Login?
Nestor
Message 4 of 8
(4,526 Views)
Dear Nestor,
          Thanks for support. but by using idea in the link provided is not working for me. I don't know what is the reson. :
As given in examle that with userid and PWD. i have to write in below method
ftp://joe:123456@ftp.ni.com/support/compworks/datasocket/tone.wav
but i could n't connect. In my case my server IP address is 202.41.112.98 and userid and password for ftp is "ayus" and "ayus".  I wrote
ftp://ayus:ayus@202.41.112.98
for browsing home folder i couldn't.
I had tried to logon on FTP server by dos command as well as internet explorer.
What mistake i am doing.
--Vishnu
Message 5 of 8
(4,477 Views)
I have WFTPD ftp server. How i can make userid-passwork based ftp client in LabWindows/CVI 6.0
--Vishnu
Message 6 of 8
(4,473 Views)
Hello Vishnu,
When you tried to log in to your FTP server using Internet Explorer did it work?
Also, I found this FAQ document for WFTPD:
http://www.wftpd.com/faq.htm#Browser
One of the things it mentions is also specifying a port when trying to connect, have you tried doing that?
Kristen
Message 7 of 8
(4,452 Views)
Dear Kristen,
         FTP server loging with internet explorer didn't work. I will try with link provided by you. Thanks
--Vishnu
Message 8 of 8
(4,427 Views)
