LabWindows/CVI
Creating Hyperlink to another cell on the workbook
I'm writing an Excel file, and want to add an hyperlink to a cell in another sheet in the current workbook.
When doing it normaly with the Excel application this type of link is called "Place in this document". However when I create the Hyperlink using the CVI Excel Report the link is created but does not function (I get an error). the address I use in the Hyperlink is :
'SHEETNAME'!A1
What am I doing wrong? maybe it can be done using the Excel 9.0 ActiveX package?
thanks,
Ido
(3,194 Views)
Hi IdoZe,
This question seems to be more of a Microsoft Excel ActiveX question than a CVI question.  I would post this question on an MSDN forum.
For an example of creating hyperlinks in CVI, see how can i put HyperLink into exel throgh CVI.
Here is more help with the Excel ActiveX API hyperlink call.
Finally, a workaround might be to create a macro that makes a link, and call this macro using ActiveX (see the excel2000dem.prj in the Example Finder).
Cheers,
David Goldberg
Software R&D
(3,165 Views)
