LabWindows/CVI
Log time in milliseconds
I am on measuring the intervals by which some interrupt occurs.
I want to log the time at which the interrupt occurs. It may by less than 1 ms.
What I could do, is to use the function "TimeStr()" but ius resolution is in seconds, so what I could get is something like that:
[12:25:10]
[12:25:10]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:11]
[12:25:12]
[12:25:12]
I want to measure these times in less than milliseconds.
(4,894 Views)
If you use the FormatDateTimeString function, you should be able to display millisecond resolution. Here is some sample code:
#define DATETIME_FORMATSTRING "[%H:%M:%S.%f]"
double currDateTime;
int bufferLen;
char *dateTimeBuffer = NULL;
GetCurrentDateTime (&currDateTime);
bufferLen = FormatDateTimeString (currDateTime, DATETIME_FORMATSTRING, NULL, 0);
dateTimeBuffer = malloc (bufferLen + 1);
FormatDateTimeString (currDateTime, DATETIME_FORMATSTRING, dateTimeBuffer, bufferLen + 1 );
(4,865 Views)
Windows provides a function called QueryPerformanceCounter. This provides excellent accuracy.
Regards, Guenter
(4,860 Views)
