LabWindows/CVI
Creating Task for USB-6008 using LabWindows CVI
I want to use NI USB-6008 with Lab Windows CVI. I have NI DAQmx 7.5 installed on my PC.
Using LabView I could access USB-6008 and could do data acquisition.
But I could not create Task for USB-6008 in LabWindows. In Lab Windows the equipment is not
getting identified. It is giving as no Physical equipment is connected.
Do you I need do anything more to work with USB-6008 from LabWindows?
Ravisankar
(4,162 Views)
I have the same behaviour here with a USB-6009 😞
However using another approach i did get some data back from ADC namely using a driver called Ni DAQ Base MX which are also installed in the NI DAQ installation.
Using the sample programs i managed to get data from the device, but it should also be possible using the DAQ library functions, did you suceed later ?
If so i would like to know how ?
B.Rgds.
Peter PBI
Denmark
(4,144 Views)
Hi
I could create task for USB-6008 from labwindows after switching to new driver.
The link below gave me hint for this. You can also try this.
[broken link removed; article no longer available]
Ravi
HYDERABAD
INDIA
(4,139 Views)
Hi again,
Thank you very much Smiley Very Happy
Just tried switching driver and now there are more life, i will exmaine this more next week.
Have a nice weekend ;o)
Peter
PBI-Dansensor A/S
(4,135 Views)
