Hello
The Activex server wizard allows you to create CVI applications that are also activex servers. CVI does not have the ability to create activex controls (ocx's, dll's ). You can use the "Activex Controller Wizard" to create wrappers that would allow you to use activex controls and servers from CVI. So you can embed an activex control on the UIR and use it from CVI.
I hope this explains things. For more information on creating Activex servers from CVI, refer to the application note that is included with CVI. Its located in the ..\bin folder, called buildingactivexservers.pdf
Bilal Durrani
NI
Bilal Durrani
NI
