11-15-2010 02:06 AM
Hi, All
i have met a problem today, i have installed DAQ driver first (DAQMX+Traditonal ) and then install the CVI. but the DAQmx and traditional FP are dimmed in CVI menu Library. althrough all of those are sucess listed in MAX . i tried to repair the driver. but no effect.
so , do someone know how to activate those FP in CVI ?
B.R
Gerry
11-15-2010 05:35 AM
The correct procedure is to install CVI first and then DAQmx, so that the installer can load the appropriate IDE support and activate the correspondin features.
Normally reinstalling DAQmx solves the problem; check also that NI-DAQmx option is checked in Library >> Customize panel.
