LabWindows/CVI
is there any example on how to create a bitmap from an array
I have a data array which i want to save as a bitmap and show on a canvas,
how can i do it?
is there aby example?
thanks
(2,968 Views)
It's a two-step procedure:
  • First, plot the data on your canvas, probably using CanvasDrawPoint (, , ); there are three NI examples for Canvas: use Help / Find Examples
  • Second, you can save the canvas control to a file using SaveCtrlDisplayToFile from the toolbox library. As an alternative, you could use GetCtrlDisplayBitmap and then SaveBitmapToBMPFile.
Wolfgang
(2,963 Views)
