LabWindows/CVI
DAQ error ---> 001B:1001C977
Hi, I'm getting an error message while running in DEBUG mode. This occurs when I break to observe a variable. This said, when I right-click to see graphically the variable (Graphical Array View), a pop-up message appears:
"Unrecoverable Internal Error at 001B:1001C977. LabWindows/CVI will be aborted."
Then pressing OK would bring the entire program to exit....
the variable under observation is dynamically allocated and the memory seems to be created and freed correctly. I'm currently using USB6211. Anyone has any ideal of this symptom? Thanks!
(2,966 Views)
We definitely want to get to the bottom of the crash you are seeing but in order for us to be able to investigate it, we will probably need to be able to reproduce here the sequence of events that led to the crash. If you preform that sequence you described again, does it crash every time?  If you can reproduce it consistently, would it be possible to provide us with a sample workspace and projects that exhibit that behavior? Does this happen on multiple machines? With different versions of CVI?
Also, it would help us if you could provide us with a crash dump. See this post for instructions on creating a crash dump.
Kristen
(2,925 Views)
