LabWindows/CVI
How can I advance the vertical scroll of a text box to the end
How can I advance the vertical scroll of a text box to the end?
(3,418 Views)
If all you need to do is to be able to see the latest text written to the text box, then using SetCtrlVal (panel, PANEL_TEXTBOX, "Some String"); to add text is the recommended method, as it automatically scrolls to the end of the box. (This should also work with an empty string if you don't want to add any data to the box contents, but I haven't got access to my CVI at the moment so I can't try it.)
JR
(3,405 Views)
Hi Steve,
You can also get the number of lines of text in the text box and then scroll to that value:
int rows;
GetCtrlAttribute (panel, PANEL_TEXTBOX, ATTR_TOTAL_LINES, &rows);            //Get total lines
SetCtrlAttribute (panel, PANEL_TEXTBOX, ATTR_FIRST_VISIBLE_LINE, rows);   //Scroll to the end
Let me know if you have any questions.
Kristen
(3,392 Views)
