LabWindows/CVI
DAQmx analog input or output: check if ready to start
I am triggering several analog input / output tasks via a start trigger. How can I ask DAQmx after writing samples (a lot of them, up to 1e6) and starting the task when the tasks can be really started ?
I experienced errors (buffer underflow)  in the analog output when starting immediately, and had to add a delay by hand to overcome them.
Message 1 of 8
(4,404 Views)
Can you please give more details ? How many analog inputs and outputs ?
Is it the same trigger to all Analog I/O ?
Kobi Kalif
Software Engineer
Message 2 of 8
(4,396 Views)
I have two DAQ M-series NI-6259 cards, RTSI on them.
I use the same sampleclock on AO and AI of both devices, created by the AO of device 1. This sanpleclock has a start trigger given by a digital; line of device 1 which I use as starttrigger for a scanning microscope setup, and also starts other hardware
the sampleclock is 10Khz, I have 2 channels on AO1 and 3 channels on AO2.
Message 3 of 8
(4,389 Views)
OK , in order to better understand how to use the DAQmx AO , AI in CVI you have a set of good examples ,
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
in there you have analog generation and measurement.
For example create a software which sets 1 ao & 1 ai at the same time by an external trigger that will give you better understating.
For each task use the Dodecahedra (DAQmxCfgDigEdgeStartTrig(gAOtaskHandle,triggerSource,triggerEdge)); function by that you will be able to set the entire system to same trigger.
Kobi Kalif
Software Engineer
Message 4 of 8
(4,384 Views)
The task configuration is not the problem, I have done this already.
I configure all the tasks with the external trigger, and then activate the external trigger.
If I activate the trigger in the code immediately after the Starttask commands, there is an error - if I wait some time after the starttask command (typically a few 100ms), it works.
How can I find out how much data is available on the ao onboard buffer to check how much data has actually been transfered to the device ?
Message 5 of 8
(4,379 Views)
I see ,
I think that waiting or checking the buffer size it's not the best way ( I don't know if there is an option check the buffer size )
I simply use DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(gAItaskHandle,DAQmx_Val_Acquired_Into_Buffer,sampsToRead,0,EveryNSamplesCallback,NULL));
I'm defining to the Device the number of samples that I want him to receive when he receives it the simply transfer it to my buffer.
For example if I'll define 1000 samples and I have 10000 samples he will make 10 events....
Look for the DAQmxRegisterEveryNSamplesEvent example it's very clear and don't forget to consider the amount of channels you have.
Kobi Kalif
Software Engineer
Message 6 of 8
(4,305 Views)
This does not help as it only gives a callback after samples have been acquired
Message 7 of 8
(4,302 Views)
Well I'm working with few of the X-Series and other units with external triggers and I had no problems like that.
What you need to do is some debug to see which AO / AI making the problem and then face it's config maybe it's something with the clock.
Try to use it with only one AO & AI if you still have a problem then it's your definitions....
Also maybe some one of NI Engineer can give you better idea's.
Kobi Kalif
Software Engineer
Message 8 of 8
(4,286 Views)
