LabWindows/CVI
catch minimize panel event (one more time)
As discussed in other threads, CVI doesn't have a specific event fired when a panel is minimized. Some workarounds has been proposed, and I successfully used the EVENT_LOST_FOCUS method for a long time.
But now I found a situation when this workaround doesn't' work:
  • if the main panel has a tab control
  • if one of the tab pages has the focus
the EVENT_LOST_FOCUS is not generated for the main panel when the application is minimized with the classical top-right "_" button in the title bar.
How can I catch the minimize panel event in this situation?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,168 Views)
Accepted by topic author vix
You can install a panel callback for all of the tab page panels.
As an example, this is how you install a panel callback for the first tab page panel.
    GetPanelHandleFromTabPage(panelHandle, PANEL_TAB, 0, &tabPanel0);
    InstallPanelCallback(tabPanel0, TabPanelCB, 0);
And then catch the EVENT_LOST_FOCUS in TabPanelCB. In order to check the WINDOW_ZOOM, you'll have to get the top level panel handle. The panel attribute ATTR_PARENT_PANEL returns the the panel handle of the parent of the panel you specify. If you pass the handle of a top-level panel, zero is returned.
Hope this helps,
- jared
(3,160 Views)
Thanks for your help, jared.
The panel attribute name is ATTR_PANEL_PARENT Smiley Wink
Vix
Using LV from 7
(3,151 Views)
