LabWindows/CVI
Using CVI Timer()
Hi ,
I want to know how to work with the CVI Timer ,
I want to test the time it takes my software to run using the timer , in the function help it says that The resolution is normally 1 microsecond.
I want to know if I see in the timer 1.7 is it in sec of microsec ? More likely sec but i want to be sure.
Kobi Kalif
Software Engineer
(3,733 Views)
Accepted by topic author Kobi_K
you might want to have a look at the example asyncdem provided with CVI.
(3,732 Views)
