LabWindows/CVI
DAQmxWriteDigitalLines disables DAQmxReadDigitalU32 on 6533
I'm working on a software using NI6533 and Ni-Daqmx
I must get continuously data on 32 bits(port 0-3) and I want to send data on the control line not used(port5).
I build 2 tasks:
- 1 to read data each 0.5s
- 1 to write data on demand
here is a summary of my code:
// continuous acquisition
    i_res = DAQmxCreateTask("Tache Acquisition Dev2",&AcqDev2TaskHandle);
    if(i_res == 0)
        i_res = DAQmxCreateDIChan(AcqDev2TaskHandle, "Dev2/port0_32", "Start Dev2", DAQmx_Val_ChanForAllLines);
    if(i_res == 0)
        i_res = DAQmxCfgSampClkTiming (AcqDev2TaskHandle, "OnboardClock", 2, DAQmx_Val_Rising, DAQmx_Val_ContSamps,        ONE_SAMPLE_PER_CHANEL);
    if(i_res == 0)
       i_res = DAQmxSetBufferAttribute(AcqDev2TaskHandle, DAQmx_Buf_Input_BufSize, 10000);
    // output task
    if(i_res == 0)
        i_res = DAQmxCreateTask("Tache output",&SyncDev2TaskHandle);
   if(i_res == 0)
        i_res = DAQmxCreateDOChan(SyncDev2TaskHandle, "Dev2/port5/Line1", "", DAQmx_Val_ChanForAllLines);
    if(i_res == 0)
        i_res = DAQmxCreateDOChan(SyncDev2TaskHandle, "Dev2/port5/Line3", "", DAQmx_Val_ChanForAllLines);
    if(i_res == 0)
        e_res = ACQ_OK;
// read function used
 i_res = DAQmxReadDigitalU32 (    AcqDev2TaskHandle,
                                    READ_ALL_SAMPLE,
                                    NO_TIMEOUT,
                                    DAQmx_Val_GroupByChannel,
                                    pui_sample,
                                    ONE_SAMPLE_PER_CHANEL,
                                    &iNumRead,
                                    NULL    );
// write function
int             i_sample_written     = 0;
unsigned char     pc_data[2]             = {0,1};
DAQmxWriteDigitalLines (SyncDev2TaskHandle, 1, 0, -1, DAQmx_Val_GroupByChannel, pc_data, &i_sample_written, 0) ;
My problem:
I read data correctly until I write data on port 5!
After a first call of the writing function, I can always read but when I call the write function for the second time, my read function returns always 0 as buffer read!!!
The Ni-DAQmx functions do not return any error.
If someone can help me, It would be wonderfull!!
Greg
(3,284 Views)
I can't reproduce this issue with your code. Could you sent me an operational example so that I can test this in the same condition?
Thanks!
(3,256 Views)
Here are the files!
I use a NI CB-68LP to connect signals with a PCB with 32 switches and 2 LEDs.
It seems that writing on a line of the port5 stop the continuous acquisition internal timer.
I tried to use change detection instead of continuous acquisition and I write on the port5 when modification occurs. It works correctly but the precision is too high for my application.
Greg
(3,245 Views)
Is anybody here to help me?
It's urgent and I do not find the solution
thanks
Greg
(3,199 Views)
