LabWindows/CVI
DBConnect - NON-FATAL RUN-TIME ERROR: Function DBConnect: (return value == -10 [0xfffffff6]). Native error code -2147217843 0x80040e4d Microsoft JET Database Engine:
I'm trying to open and read a table of database access (2007) protected by a password. I'm using Labwindows/CVI2012.
The problem is that I'm getting this error in "DBConnect" function :
Can not start your application. The workgroup information file is missing or opened exclusively by another user.
My code is really simple : I'm calling the "ConnectBase" function using my "Index" parameter (wich is 3 in my case)
ConnectBase(int iIndex, char * BaseName)
    int error=0,i=0;
    //char tcTestCheminDB[MAX_PATH_LENGTH]="";		//DB Globale
	char tcDBGlobalPath[MAX_PATH_LENGTH]="";		//DB Globale
	char tcDBProjPath[MAX_PATH_LENGTH]="";	//DB Projet
	char tcReportText[200];
	(1000 * sizeof(char));
	switch(iIndex)
	 case 0:
	 case 1:
	 case 2:
	 case 3:
	//HA Modification 05/11/2015
	 sprintf(Connection_DB_Texem_Local,"");
	 GetDatabasePath (BaseName, tcReportText, tcDBProjPath, 0);
	 strcat (Connection_DB_Texem_Local, "Provider=Microsoft.Jet.OLEDB.4.0;Password=JEmxa07<;Data Source=");
	 for (i = 0 ; i < strlen(tcDBProjPath) ; i ++)
	  if (tcDBProjPath[i] == 92)
	   strcat (Connection_DB_Texem_Local,"\\");
	  else
	    Connection_DB_Texem_Local[strlen(Connection_DB_Texem_Local) + 1] = 0;
		Connection_DB_Texem_Local[strlen(Connection_DB_Texem_Local)] = tcDBProjPath[i];
	  strcat (Connection_DB_Texem_Local,";Mode=ReadWrite;Persist Security Info=False;");
     //Use simple Thread
     ErrChk_DB(DBInit (DB_INIT_MULTITHREADED));
     //Connect to the DB
     // ErrChk_DB(tiConnectionHandle[iIndex] = DBConnect (CONNEXION_BASE));
	 if(tiConnectionHandle[iIndex]>0)
	  DisConnectBase(iIndex);
      ErrChk_DB(tiConnectionHandle[iIndex] = DBConnect (Connection_DB_Texem_Local));
	 else
	   //DisConnectBase(iIndex);
	 break;
    return 1;
Error:
    return error;
The error is happening in the red line.
Any idea please to solve that ?
(5,582 Views)
What is the function of DisConnectBase() ? Could you show us the code ?
The error says that you try to open an already opened database and  according to its naming DisConnectBase() may close the database so that the problem doesn't happen in the other case of your if statement
(5,552 Views)
DisConnectBase(int iIndex)
    int error = 0;
  if (tiConnectionHandle[iIndex]>0)
   ErrChk_DB(DBDisconnect (tiConnectionHandle[iIndex]));
   tiConnectionHandle[iIndex] = -1;
  return 1;
Error:
    return error;
(5,537 Views)
Besides, I think that tiConnectionHandle[iIndex] condition is not good.
I have 3 DB connection. tiConnectionHandle is a table where I should pour the reslut of each DBConnect(handle) of the three connection.
NOTE : It's 3 different DB.
(5,536 Views)
