LabWindows/CVI
SQL Toolkit 2.2/2.3 installation failed
I'm trying to install SQL Toolkit on my computer under Windows 10 but each time I tried the installation, it is blocked at 0%.
I tried to install with Windows under safe mode and I got this messages:
-SQL Toolkit 2.3: Error TARGETDIR is undefined, the Directory table seems malformed. Aborting...
-SQL Toolkit 2.2: The NI Labwindows/CVI SQL Toolkit 2.2 installation has failed with the following error: Unable to access the service Windows Installer.This can happen if the Windows Installer is not correctly installed.
I contacted Windows Answer Desk and my Windows Installer seems work correctly...
Thank you for your help.
(4,769 Views)
The SQL Toolkit version 2.2 or 2.3 aren't compatible with Windows 10:
ReadMe SQL Toolkit 2.3
Supported OS are : Windows 8.1; Windows 8; Windows 7; Windows Server 2012 R2 64-bit; Windows Server 2008 R2 64-bit
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(4,743 Views)
Thank you Valentin.B,
But I succeed to install SQL Toolkit 2.3 on Windows 10 by disabling Windows Installer in the Task Manager.
Jean-Marc ROTH
(4,717 Views)
