LabWindows/CVI
DDE server connect / disconnect
I have a few flowmeters in system. Each of them is sitting at different DDE server, named FlowDDE, FlowDDE2, etc. 5 in total.
I'm connecting through:
ConnectToDDEServer (&hConv, "FlowDDE", "C(1)", DDECallback, 0);
ConnectToDDEServer (&hConv, "FlowDDE2", "C(1)", DDECallback, 0); etc.
and everything works well.
To disconnect there is command:  DisconnectFromDDEServer (0);
However, it's not exactly what I want to do... this command breaks all connections with specification.
So my question: is there any command with specification for disconnection? or is there any way to specify server name into DisconnectFromDDEServer ?
Thank you,
Alexey.
UPDATE: /Solved/
I recognised, that I can add different unsigned int
static unsigned int hConv, hConv2;
DisconnectFromDDEServer (hConv);
ConnectToDDEServer (&hConv2, "FlowDDE2", "C(1)", DDECallback, 0);
DisconnectFromDDEServer (hConv2);
works well.
(3,696 Views)
Hi ALL
Can someone put a simple example for call a specific parameter into specific node?
For instance,  Measure or setpoint.
Thanks in advance
Jose
(3,357 Views)
Hi Jose,
It looks like you have posted on a very old thread.  I think you might find more luck getting replies if you try to start a new post.  Also, it might help if you elaborate a little more in your question, or post a suggestion and ask for comments.
Best wishes!
Amanda B.
(3,344 Views)
