LabWindows/CVI
Is there any Excel Library files to generate excel file?
Im trying to generate an Excel report file. Can any one please suggest me how to create/generate .xls file with CVI API's.
I wanted to do this without the help of Microsoft Office.  My machine is not installed with MS office.
Nayana
(4,567 Views)
Hello Nayana!
You need Excel installed on your machine, in order to be able to generate .xls documents.
Check some examples from the CVI samples directory: <CVI Installation Directory>\samples\activex\excel
You can use those sample projects for extending them to your needs.
Best regards!
- Johannes
(4,564 Views)
