DLL Version Information in CVI-RT
Is there a way to obtain version information of DLL's in CVI-RT?  The supported WIN32 API functions does not appear to include the following functions:
- GetFileVersionInfoSize()
- GetFileVersionInfo()
(3,591 Views)
Hello tedoyle,
If you are just interested in getting the file version information, you could try the following (error checking omitted for brevity):
void CVIFUNC_C RTmain (void)
    char *              fileInfo;
    char *              lock;
    int                 size = 0;
    HMODULE             module = 0;
    HRSRC               resource;
    HRSRC               loaded;
    VS_FIXEDFILEINFO *  pFFI;
    if (InitCVIRTE (0, 0, 0) == 0)
        return;    /* out of memory */
    Cls();
    printf("\n\n\n\n\n");
    module = LoadLibraryEx("c:\\ni-rt\\system\\cvi_lvrt.dll", NULL, DONT_RESOLVE_DLL_REFERENCES);
    resource = FindResource (module, MAKEINTRESOURCE(1), RT_VERSION);
    loaded = LoadResource (module, resource);
    lock = LockResource (loaded);
    size = SizeofResource(module, resource);
    fileInfo = malloc(size);
    memcpy(fileInfo, lock, size);
    pFFI = (VS_FIXEDFILEINFO *)((DWORD *) fileInfo + 10);
    printf("\nThe version of cvi_lvrt is %d.%d.%d.%d\n\n",
            HIWORD(pFFI->dwFileVersionMS),
            LOWORD(pFFI->dwFileVersionMS),
            HIWORD(pFFI->dwFileVersionLS),
            LOWORD(pFFI->dwFileVersionLS));
    if (fileInfo)
        free(fileInfo);
    if (module)
        FreeLibrary(module);
    CloseCVIRTE ();
Let me know if you have any questions
NickB
(3,556 Views)
Thanks for the information.  The example seems to work with LabWindows generated DLL's.  However, it did not work with a DLL generated under VS2005.  The FindResource() function failed.  I didn't dig into the reason.  Will probably look into this in more detail tomorrow.  Anyway, thanks again for the reply!
(3,538 Views)
under Visual Studio, the generated executable does not have a Version resource by default. you have to add it yourself.
this is very easy to accomplish: on the solution explorer tab, right click on your project and select "Add/Resource...". in the dialog box which appears, select "Version". now go to the Resource View and edit the version resource. don't forget to frequently set a new version number for your executable. (i don't know any way to automatically increment the version number).
(3,518 Views)
