I am attempting to do a 3 channel, single rate scan of signals coming
from sensors through the PCI-6071E using LabWindows. I have used both
a program I wrote myself and the LabWindows sample multi-channel
scanning program and received the same results. When I run a test
program, one signal comes through fine, but the other two do not. The
other signals usually sit around 0 V with a little fluctuation, but
when I begin my SCAN they drop to around -2 & -4 V. At the end of the
SCAN process, the signals return to there normal state, but that data
that has been read in is the incorrect data. I can see this happening
on an oscilloscope I have attached to the line as well, so I know the
readings from the card are correct. Is there somet
hing I am doing
with my programs that is causing this, or does this show some kind of
hardware setup issue?
Any help would be appreciated.
