LabWindows/CVI
Data Tooltip corruption
It appears that the Data Tooltip in the CVI editor does not like bool...
I am attaching three pictures to illustrate the process: there is some code (a function), and when typing the Data Tooltip shows the function definition; this mostly works except sometimes, see below. 'Sometimes' seems to be related to boolean function definitions
1)
2)
3)
(5,436 Views)
Hi Wolfgang,
I haven't been able to reproduce this yet. Here is what I did:
I don't know if it depends on how bool is defined. Can you reproduce this outside of your project and, if so, can you share your definition of bool?
Luis
(5,385 Views)
Thanks for trying...
I used
#include <stdbool.h>
(5,382 Views)
Hi Luis,
I have been able to reproduce it in a simple demo, see below:
(5,365 Views)
Thanks, Wolfgang. With your help, I've reproduced and confirmed the bug: 473109.
The difference here is in the use of the clang-intrinsic _Bool data type (via stdbool,h). If you define bool yourself to something else (for example, typedef int bool), then the bug doesn't happen.
(5,342 Views)
Thanks Luis!
(5,338 Views)
