LabWindows/CVI
Modify camera attributes with an .ini file
Hello.
I would like to change some camera attributes thanks to an INI file, before running the User Interface.
The problem is that when I display the values of the modified attributes, they are not modified : it is still the same values as in the NIMAX camera file .
In fact I opened an IMAQdx session with IMAQdxOpenCamera, then I loaded the value from Camera.ini to the Camera Attributes, and finally I closed the session with IMAQdxCloseCamera.
I look forward to seeing your ideas!
Thomas1330
(5,123 Views)
Check if this ini file is not in "read only" mode.
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(5,062 Views)
Accepted by topic author thomas1330
in fact I resolved the problem.
I used the following function :  IMAQdxReadAttribute (id session, ini_pathname)  --> only the attributes written in the .ini are changed in the camera file, until I close my program Smiley Wink
Thomas1330
(5,052 Views)
