LabWindows/CVI
DateStr outputting incorrect value?
I got a report of an anomaly on a production application.  It occurred yesterday.  A few UUTs apparently "skipped ahead" by several hours of testing inexplicably.  My software records unit test results every 4 seconds, so I have pretty good visibility of such errors.  Here is a screenshot:
Notice columns 2-3.  These are produced by calls to DateStr() and TimeStr().  Several columns over, you'll see a test time string also in HH:MM:SS format.  This value is calculated by calling GetCurrentDateTime().
You'll notice that between the Date/TimeStr columns and my elapsed column, they agree that some sort of time warp happened, to the tune of 27 hours!
I checked the PC's real time clock.  It was correct to within a few minutes, correct date, correct AM/PM.
This codebase has been released and stable for a few years now, so I wouldn't expect issues around the use of this part of my logging mechanism.  This is the first time I've ever witnessed an error quite like this where I couldn't depend on CVI's date/time functions.
Should I be worried?
(3,621 Views)
Are you absolutely sure nothing happened outside your application, such as a clock correction via NTP, or similar?
Carlo A.
Megaris srl
Italy
(3,540 Views)
No, I'm not completely sure.  Although our production floor keeps these computers disconnected from the internet for that reason.
I starting to think that this PC "hung up" for several hours and recovered.
(3,536 Views)
Have you looked for hints of any strange behaviour in Windows' Event logs ?
Carlo A.
Megaris srl
Italy
(3,528 Views)
I did.  No errors or warnings in that time frame.  I'm going to swap out computers next.
(3,501 Views)
