LabWindows/CVI
DateStr outputting incorrect value?
I got a report of an anomaly on a production application.  It occurred yesterday.  A few UUTs apparently "skipped ahead" by several hours of testing inexplicably.  My software records unit test results every 4 seconds, so I have pretty good visibility of such errors.  Here is a screenshot:
Notice columns 2-3.  These are produced by calls to DateStr() and TimeStr().  Several columns over, you'll see a test time string also in HH:MM:SS format.  This value is calculated by calling GetCurrentDateTime().
You'll notice that between the Date/TimeStr columns and my elapsed column, they agree that some sort of time warp happened, to the tune of 27 hours!
I checked the PC's real time clock.  It was correct to within a few minutes, correct date, correct AM/PM.
This codebase has been released and stable for a few years now, so I wouldn't expect issues around the use of this part of my logging mechanism.  This is the first time I've ever witnessed an error quite like this where I couldn't depend on CVI's date/time functions.
Should I be worried?
(3,615 Views)
Are you absolutely sure nothing happened outside your application, such as a clock correction via NTP, or similar?
Carlo A.
Megaris
(3,534 Views)
No, I'm not completely sure.  Although our production floor keeps these computers disconnected from the internet for that reason.
I starting to think that this PC "hung up" for several hours and recovered.
(3,530 Views)
Have you looked for hints of any strange behaviour in Windows' Event logs ?
Carlo A.
Megaris
(3,522 Views)
I did.  No errors or warnings in that time frame.  I'm going to swap out computers next.
(3,495 Views)
