LabWindows/CVI
Detect hardware capabilities of a DAQmx device
When dealing with data acquisition devices it is sometime useful to programmatically detect hardware capabilities of them. I presently need to deal with AO channels of several USB devices and would like to limit user ability to set the output value to the actual range of device channels (which can be for example 0-5V or 0-10V or -10-10V) in order to prevent getting errors. How can I do this?
I cannot use DAQmxGetChanAttribute since this function requires the channel to be added to a task but in that step you state min/max limits and DAQmxGetChanAttribute reflects those limits even if lower than max possible values.
I have been digging into NI System Configuration but could not find an appropriate function.
Suggestions are welcome!
(2,901 Views)
Hi Roberto,
I'm not sure I understand.
You want to set limits on the user interface that correspond to the channel capabilities ? Or you want to change the software limits of the channels ?
And you want to do either of those without defining a task ?
(2,881 Views)
Accepted by RobertoBozzolo
Hi Roberto
This code snip is a part of mach larger program that i can not share.
Hope it will help you.
int SetupAnalogIn(int board_index)
int size , i , no_channels , *types = NULL ;
char *channels = NULL , str[128] ;
double rate , *ranges ;
size = DAQmxGetDeviceAttribute (DevInfo[board_index].DevName,DAQmx_Dev_AI_VoltageRngs, 0, 0);
ranges = (double *)malloc(size* sizeof(double)) ;
DAQmxGetDeviceAttribute (DevInfo[board_index].DevName,DAQmx_Dev_AI_VoltageRngs, ranges, size);
free(ranges) ;
size = DAQmxGetDeviceAttribute (DevInfo[board_index].DevName, DAQmx_Dev_AI_PhysicalChans, 0, 0);
if(size <= 0)
return 0 ;
channels = malloc(size) ;
if(channels == NULL)
MessageBox(HWND_DESKTOP,"Unable to allocate memory","NiPanels", MB_ICONERROR | MB_OK | MB_SYSTEMMODAL);
return 0 ;
DAQmxGetDeviceAttribute (DevInfo[board_index].DevName, DAQmx_Dev_AI_PhysicalChans, channels, size);
DevInfo[board_index].hWnd_AnlgIn = LoadPanel(0 , "NiPanels.uir" , ANLG_IN) ;
if(DevInfo[board_index].hWnd_AnlgIn <= 0)
return 0 ;
sprintf(str , "%s:%s Analog In",DevInfo[board_index].Type,DevInfo[board_index].DevName) ;
SetPanelAttribute(DevInfo[board_index].hWnd_AnlgIn ,ATTR_TITLE , str) ;
SetCtrlVal(DevInfo[board_index].hWnd_AnlgIn , ANLG_IN_DEV_NO , board_index) ;
//get all channels
for(i = 0 , no_channels = 0 ; i < size ; )
if(!CopyUntilComma(&channels[i] , str , 64))
break ;
no_channels++ ; i += strlen(str) + 1 ;
InsertTableRows(DevInfo[board_index].hWnd_AnlgIn ,ANLG_IN_TABLE , -1 , 1 , VAL_USE_MASTER_CELL_TYPE) ;
SetTableCellAttribute(DevInfo[board_index].hWnd_AnlgIn , ANLG_IN_TABLE , MakePoint(1,no_channels) , ATTR_CTRL_VAL , str) ;
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,2,no_channels,1) , -1, "RSE");
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,2,no_channels,1) , -1, "NRSE");
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,2,no_channels,1) , -1, "Diff");
//check for TC capable channels
size = DAQmxGetDeviceAttribute (DevInfo[board_index].DevName,DAQmx_Dev_AI_SupportedMeasTypes, NULL,0);
types = malloc(size * sizeof(int)) ;
if(types == NULL)
return 0 ;
DAQmxGetDeviceAttribute (DevInfo[board_index].DevName,DAQmx_Dev_AI_SupportedMeasTypes, types,size);
for(i = 0 ; i < size ; i++)
if(types[i] == DAQmx_Val_Temp_TC)
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,2,no_channels,1) , -1, "Temp");
InsertListItem(DevInfo[board_index].hWnd_AnlgIn , ANLG_IN_ALL_CHAN_CFG , -1 , "Temp","Temp") ;
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,6,no_channels,1) , -1, "");
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,6,no_channels,1) , -1, "J");
InsertTableCellRangeRingItem (DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, MakeRect(1,6,no_channels,1) , -1, "K");
SetTableColumnAttribute(DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_TABLE, 6 , ATTR_COLUMN_VISIBLE , 1) ;
SetTableCellRangeAttribute (DevInfo[board_index].hWnd_AnlgIn,ANLG_IN_TABLE, VAL_TABLE_COLUMN_RANGE(6), ATTR_CELL_DIMMED, 1);
break ;
free(types) ;
DAQmxGetDeviceAttribute (DevInfo[board_index].DevName,DAQmx_Dev_AI_MaxSingleChanRate, &rate,1);
SetCtrlAttribute(DevInfo[board_index].hWnd_AnlgIn, ANLG_IN_SAMP_RATE , ATTR_MAX_VALUE , rate) ;
DisplayPanel(DevInfo[board_index].hWnd_AnlgIn) ;
free(channels) ;
return 1 ;
(2,869 Views)
@gdargaud  ha scritto:
Hi Roberto,
Yes, I want to st user limits the same as hardware capabilities, so that the system is not likely to get an error due to invalid values attempted.
AFAIK this cannot be done safely by defining a task, since you add a channel to it with a call to
DAQmxCreateAOVoltageChan (taskHandle, "channel", "", -10.0, 10.0, DAQmx_Val_Volts, "");
in which you  must set min/max limits. Supposing you don't get an error in this function by setting incorrect values, the limits you set here are reflected in DAQmxGetChanAttribute (..., ..., DAQmx_AO_Max, ...), so you don't get board capabilities but your settings instead.
(2,859 Views)
@GabelDaniel  ha scritto:
size = DAQmxGetDeviceAttribute (DevName, DAQmx_Dev_AI_VoltageRngs, 0, 0);
return 1 ;
That was the solution (in my case with DAQmx_Dev_AO_VoltageRngs attribute) ! It didn't occurred to me to query for device attributes!
Thanks Daniel
(2,853 Views)
