LabWindows/CVI
Determination of Integer values
I tried to build a short program to determine whether there is an integer value in a floating point numeric control.
It is working fine as long as I am using the keyboard to change the values confirming with enter.
But if I use the increment and decrement buttons to change a value only the number I entered with the keyboard is detected to be an integer.
E.g. I write a 2 into it and press enter -> integer
(3,067 Views)
I wrote a quick test case with the callback below and it successfully detected integers and non-integers, even if I changed the value with the increment/decrement buttons.  Hope this helps.
int CVICALLBACK numericChange (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_COMMIT:
   GetCtrlVal(panel, PANEL_NUMERIC, &controlValue);  // note - controlValue is a double
   if ( fmod(controlValue,1.00) != 0) SetCtrlVal(panel, PANEL_LED, 0);
   else SetCtrlVal(panel, PANEL_LED, 1);
   break;
 return 0;
Kevin C.
(3,059 Views)
